How does one draw a complex curved line to act as the path for a sweep in REVIT 14?
I need to create an arch (shown in elevation), that follows a curved path (shown in plan).
Thanks a million - John
What path? The reference line that you show on the right side, or the path created by the circles?
Anyway, it can be made with the Sweep tool. It is better to make a profile family of the vault, first. Within the Sweep tool, use pick lines > pick 3d edges to include both the arc and the line in the path. Then, apply the profile, and finish the sweep.
Maybe the circles want to be Reference Points ? Are they?
Constantin Stroescu
are you working in Conceptual Mass or In-Place Mass from Project's Massing and Site ?
And your circles are they Reference Points?
Constantin Stroescu
The sweeped arch could be made using a workaround as mass element.
I made a Conceptual Mass element , but it can be done also in project as In Place Mass. The idea is to make two extruded objects and to use there intersection lines as path for the sweep (follow the number of the files from attachment):
Constantin Stroescu
Another possible solution, just in case if the intention was to create a continuous surface, not some "tubes" as in the photo of the model is this: 3 arcs, made with reference splines, maybe the mid arc with an offset inward, in relation to the two other arcs, to make the surface with double curvature, like this:
Thank to everyone for your help and suggestions. Thanks constantin.stroescu for your step by step instructions. I took your idea and ran with it. After some trial and error, it worked!
As a reference, here are my revised step by step instructions in REVIT 2014:
Create Tab > Forms Panel > Extrusion.
2. In plan, make an Void Form using the plan curve as an edge. (Horizontal Work Plane)
Create Tab > Forms Panel > Void Forms drop-down > Void Extrusion.
The resultant volume is a “boolean subtraction” of the two volumes and the itersection line will be the sweep path for the desired arch form.
3. In 3D View, create the final sweep.
Create Tab> Forms Panel > Sweep > Pick Path …
Ah, so it is made of tubes. What is that anyway, a sculpture?
It's a folly. An arch form, morphed into a large swing, weighted to return to the pictured position when not in use.
Thanks for your help.
John.
