Creating Window
1 REPLY 1
kate_vanhout
194 Views, 1 Reply
Creating Window
I am trying to create a Window with adjustable colonial and prairie grids.  I have created many windows like this so I know I am able to do it.  I am currently working on creating the colonial grids.  I have it partially working.  I can adjust the height and the grids will move correctly with the window with no problems.  But when I try to adjust the width I get the error "constraints are not satisfied" I have no idea why I keep getting this error message because to me this should work and I have run into this same problem multiple different times.  What am I doing wrong?  Why can I adjust the height and not width?
1 REPLY 1
in reply to: kate_vanhout
it's about the symbolic lines in your floor plan
if you put them in a seperat family then it's easier to let them follow the main family
