I am trying to create a Window with adjustable colonial and prairie grids. I have created many windows like this so I know I am able to do it. I am currently working on creating the colonial grids. I have it partially working. I can adjust the height and the grids will move correctly with the window with no problems. But when I try to adjust the width I get the error "constraints are not satisfied" I have no idea why I keep getting this error message because to me this should work and I have run into this same problem multiple different times. What am I doing wrong? Why can I adjust the height and not width?
it's about the symbolic lines in your floor plan
if you put them in a seperat family then it's easier to let them follow the main family
