Hello All,
I started a new project. I linked a revit file. I copy monitored key levels from the linked file. The color of the level heads is black and this indicates that there are no associated plan views. My question is, what is the best way to create plan views from the copy monitored levels? See image attached.
Thanks in advance,
Steve
Solved by LisaDrago. Go to Solution.
You can certainly create plan views from these!
If you go to the View Tab>Create Panel>Plan Views, selct the leve you need to create and click Okay. it will then open up and you will see it in your project browser.
I have attached some images for reference.
LD
