I have attached the Elevation Tag I have attempted to create. The pointers are included. Why are the text and line rotating when I create an Elevation using this tag ? I am using three pointer families.
Solved by ryan.duell. Go to Solution.
Please let me know if adding a second pointer family for the right side works for you ion this issue as well. I included the video and example file below as well.
<File attached>
Video Example: http://www.screencast.com/t/7nDuMzHtNznI
Thanks again,
Issue resolved by ensuring all pointer families are oriented in the same direction [facing up]. Then load them into body family, and rotate there as necessary.
Here is a post expanding on the issues to keep in mind for custom elevation tags:
Thank you,
