Create .csv file from dxf
2 REPLIES 2
siwilks200
2039 Views, 2 Replies
i have downloaded a dxf containing 3D point data from Promap, i need to insert this into Revit for modelling. i cant see how to create a .csv file using autocads data extraction wizard as it only recognises .dxe files. please help, i have managed to do this ages ago but now cannot
2 REPLIES 2
siwilks200
in reply to: siwilks200
apologies, i was reading the box incorrectly - i had to start naming the dxf file as a dxe - go thro the extraction - and then create a csv. that was ok problem solved so then i followed my previous thread/problems found here http://discussion.autodesk.com/forums/thread.jspa?threadID=696512&tstart=975 but i am still getting the single line problem, the originally downloaded data from promap is attached for your info
m.redmond
See http://www.ledboots.co.uk Edited by: m.redmond on Sep 9, 2009 8:44 AM
