Corrupt element causes file to become corrupt - unable to recover
5 REPLIES 5
mickdunn
561 Views, 5 Replies
I have been receiving the error "Element 1013806 became corrupt at some time before this session" etc.  I get prompted to create a recovery file however the recovery file and the original file are both rendered corrupt and cannot be opened.  I am prompted to send the file to Autodesk to be recovered.  A couple of problems - the file is over 100mb and anytime I try to do anything through subscription centre (lodge support request, download latest versions etc), I end up with page not found errors at all URLs beginning with: https://login.salesforce.com/?  It doesn't matter which browser I use.
This file has, of course, become corrupt on a major submission date.  I am able to rollback to a previous version but am unable to delete the offending element and it's only a matter of time before I accidentally stumble across said element again causing the whole process to repeat.
If I could have directly lodged a support request I would have.  I can be contacted directly via email if that is preferable.
5 REPLIES 5
LisaDrago
in reply to: mickdunn
Have you opened a support ticket with Autodesk support without trying to attach the file?
Do you have a case number?
Usually they will give you an area you can upload a large file for them to assist.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
mickdunn
in reply to: LisaDrago
The problem is I can't open a support ticket because I can't get onto their support site. It always fails to resolve the DNS for me. I was hoping someone could provide me with a different way to get in touch.
LisaDrago
Okay, let me see if I can escalate this from here...
LD
mickdunn
Thank you for your help but I was able to get through to support and open a case. Not sure what the issue was but it seems to have resolved itself (the DNS issue, not the file corruption).
LisaDrago
Okay, glad you were able to get to them.
LD
Rail Community
