Revit Architecture
New Member
Message 1 of 5 (481 Views)
Corner Trim
481 Views, 4 Replies
10-11-2007 09:12 AM
I am curious if anyone has found any particularly good way of adding exterior vertical corner trim to a model, say, 2x6 or 2x8 wrapped around a corner.
Member
Message 2 of 5 (479 Views)
Re: Corner Trim
10-11-2007 09:17 AM in reply to: mtnsmith
I would just make a corner trim family and make an extrusion the height and size you need. You could then add a detail component to the family if you wanted it to show a wood hatch, etc. for a plan section detail.
*cdv
Message 3 of 5 (481 Views)
Re: Corner Trim
10-11-2007 06:21 PM in reply to: mtnsmith
Try the attached file I got from revitcity.
wrote in message news:5746958@discussion.autodesk.com...
corner.
Distinguished Contributor
Message 4 of 5 (480 Views)
Re: Corner Trim
10-14-2007 04:50 AM in reply to: mtnsmith
Hosted Wall Sweeps from the Model tab of the Design Bar allow you to have horizontal and vertical sweeps. I have used this tool as well as creating a corner board family as recommended by the other posts.
You could also create an in-place family for this corner board condition if you do not want to create a new family (RFA file).
Mel Persin, AIA
AEC Technology Consultant
Technology to Visualize and REalize Solutions
MasterGraphics, Inc.
Member
Message 5 of 5 (482 Views)
Re: Corner Trim
10-15-2007 10:16 AM in reply to: mtnsmith
I did the same thing as Mel Persin suggested. I created a parametric profile, and use it as a vertical wall sweep. You have to watch that you are snapping the sweep to the end of the wall, and if you change the exterior finish thickness, the sweeps can get deleted. There is also a flip profile symbol that allows you to flip the profile so that it is facing the correct direction after being placed. I also found that you should place the sweeps one corner at a time.
Chris St.Clair
cstc@mts.net
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
