Revit Architecture
*Damian Bree - BDP
Message 1 of 2 (873 Views)
Coping to top of Parapet Wall
873 Views, 1 Replies
05-09-2004 03:49 AM
I'm looking for a way to place a concrete coping to the top of a (level) parapet wall. I cannot find any such family in the library, but being new to Revit I may be looking in the wrong area, or using UK terminology. Any guidance please? On a similar vein, at the other end of the wall, is there a Foundation (sometimes called footing) family, so that the structure is represented correctly in sections? Thanks Damian
*Aaron Rumple
Message 2 of 2 (873 Views)
Re: Coping to top of Parapet Wall
05-10-2004 06:13 AM in reply to: *Damian Bree - BDP
1. You can either design the coping into the wall family using a wall sweep. Or you could create a hosted sweep on just specific walls. The tutorials have a good exercise for learning how to do this. 2. For foundations you can use: A short fat wall. A wall sweep. A hosted sweep. A floor. Much depends on the construction details of the project. "Damian Bree - BDP" wrote in message news:409e0cbd$1_2@newsprd01... > I'm looking for a way to place a concrete coping to the top of a (level) > parapet wall. > > I cannot find any such family in the library, but being new to Revit I may > be looking in the wrong area, or using UK terminology. Any guidance please? > > On a similar vein, at the other end of the wall, is there a Foundation > (sometimes called footing) family, so that the structure is represented > correctly in sections? > > Thanks > > Damian > >
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
