Converting voids
6 REPLIES 6
IMCornish
5111 Views, 6 Replies
Converting voids
Can a void be converted to a solid?
Andrew Robertson
Chartered Architect
Robertson Partnership
Truro. UK
6 REPLIES 6
Alfredo_Medina
in reply to: IMCornish
Yes, you can select a void, and convert into a solid, or convert a solid into a void.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
IMCornish
in reply to: Alfredo_Medina
Alfredo, I was aware of this opportunity with solids to voids but 'my voids' do not seem to offer this choice, see partial screen view with a swept blend void form selected adjacent to Properties window:Void to Solid.png
The void, although selected appears to have no properties! Any ideas please?
Andrew Robertson
Chartered Architect
Truro. UK
CoreyDaun
Is the Void part of a Group? I've found that you do not have this option in this case - you cannot change a Void to a Solid or vice versa in Groups.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
IMCornish
in reply to: CoreyDaun
No, it is not in a group.
Andrew Robertson
Chartered Architect
Truro. UK
CoreyDaun
Also, if the Void is cutting any other extrusion, you cannot change it to a Solid. It is possible for a Void to be set to cut an extrusion that it does not even contact, so to remedy this, select the Void and then to Modify tab » Cut ▼ Uncut Geometry. Hover the cursor over the other extrusions, and if any of them become highlighted, then click to disassociate these elements. Once the Void is no longer cutting any elements, you will be able to change it to a Solid.
IMCornish
Corey
thank you, that is the key. The void needs to be dissassociated with the object it is cutting before it can be converted. Have accepted what you have said as the solution. This advice should be documented in WikiHelp.
Andrew Robertson
Chartered Architect
Truro. UK
