Conversion of 3D to MicroStation
2 REPLIES 2
277 Views, 2 Replies
Can the working units be changed from "12:8000" to something else before the file is exported to MicroStation? Thanks for any help. John
2 REPLIES 2
We export to DGN, reference the export into a seed file, then merge the reference. This forces the seed files settings onto the Revit export. The dgn Settings file option when exporting does not work, it is broken.
We have not ever done export to 3D however, only for background 2D data. I imagine that using a 3d seed file should yield similar results however.
HTH
Yeah, I knew we could do that, I was looking for a fix that would be transparent. Easy enough to use a intermediate file and have the exported attached at a scale and periodically delete all and copy from the reference in place. It would be no problem to do as you suggest, but the person requesting wants a "effortless" export so they don't have to tweak the files. Not my choice. We have a need to produce models, that Revit can easily do, and export them to DGN for use with PDS(Intergraph Plant Design), and it wants "12:2032" rather than "12:8000". Thanks though....... "Steve_Stafford" wrote in message news:12750823.1078877677085.JavaMail.jive@jiveforum2.autodesk.com... > We export to DGN, reference the export into a seed file, then merge the reference. This forces the seed files settings onto the Revit export. The dgn Settings file option when exporting does not work, it is broken. > > We have not ever done export to 3D however, only for background 2D data. I imagine that using a 3d seed file should yield similar results however. > > HTH
