Revit Architecture
Active Contributor
Message 1 of 12 (418 Views)
Accepted Solution
Controlling the font thickness/boldness for generic annotation within a family
418 Views, 11 Replies
01-31-2013 01:50 PM
I have a generic annotation family embedded in a family and when I bring the family into a project, the text becomes extra bold.  If I bring that exact same generic annotation family into the same project, the text looks fine.  Please see the attached image.  The top text is the generic annotation family embedded in the electrical fixture family.  The bottom is the same generic annotation family dropped directly into the project.
Any idea on how to control the boldness of the text of the generic annotation family embedded within the electrical fixture family?  And I have to use an embedded generic annotation family for visibility control issues.
*Expert Elite*
CADastrophe
Message 2 of 12 (399 Views)
Re: Controlling the font thickness/boldness for generic annotation within a fami
02-01-2013 05:22 AM in reply to: ArynBergman
Two questions: What version of Revit are you using? Can you post your electrical fixture family here?
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Valued Contributor
Message 3 of 12 (393 Views)
02-01-2013 05:43 AM in reply to: ArynBergman
Does it plot that way or just on the screen???
David William Edwards
Senior Architectural Designer / BIM Manager
Sherlock, Smith & Adams, Inc.
Active Contributor
Message 4 of 12 (380 Views)
02-01-2013 10:28 AM in reply to: CADastrophe
I'm using Revit 2013 with the 2nd service update and yes I can.
Thanks!
Active Contributor
Message 5 of 12 (379 Views)
02-01-2013 10:30 AM in reply to: davidwilliamedwards
We haven't tried plotting it, but the team won't be using plots much anyways.  They care about how it looks on the screen.
*Expert Elite*
CADastrophe
Message 6 of 12 (370 Views)
02-01-2013 11:25 AM in reply to: ArynBergman
I loaded both the Electrical Fixture and the Generic Annotation Families into a Project, and the text from both appears correct. Is the text mismatched if you load them into a new project? Also, if opened from another computer, does the text appear incorrect there as well?
Active Contributor
Message 7 of 12 (362 Views)
02-01-2013 04:14 PM in reply to: CADastrophe
Yeah, I compared the tags on a different machine with a new project and it they still look different.  Weird.  Well, its not a huge deal and I appreciate the effort.
Active Contributor
Message 8 of 12 (303 Views)
02-05-2013 10:13 AM in reply to: ArynBergman
Hi guys, so the problem has gotten a bit more serious.  When we try to print a pdf, the generic annotation embedded within family is extremely grainy with most of it unreadable.  We tried printing with Bluebeam, Adobe Acrobat Pro, with resolutions of up to 1200 dpi, and I've changed every setting I could find under the printing options with no luck.  Please see the image below:
Any ideas on how to clean up the embedded generic annotation?
Product Support
Message 9 of 12 (295 Views)
02-05-2013 01:37 PM in reply to: ArynBergman
I would suspect that the nested family is being rasterized (and this is what is causing the text to be blurry).
Try turning any shaded elements off (within the family and / or view), and see if the issue is cleared.
Lance Coffey
Active Contributor
Message 10 of 12 (284 Views)
02-05-2013 05:23 PM in reply to: Lance.Coffey
Hi Lance, I'm not sure what you mean by turning off any shaded elements.  Could you please explain?
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
