Again I seem to be having a lot of problems with my Contextual Ribbon. This time for Modify Fascias. I am not getting the Remove Fascia Segments button of the Roof Fascia Panel of the Contextual Ribbon; nor the Mitering Panel with the Vertical and Horizontal mitering buttons. I am getting the Restart Fascia button for the Placement Panel Contextual Ribbon. Either my system is malfunctioning or I am doing something wrong or I have been hacked. Because I built this computer from scratch specifically for working in Revit and I have a lot of top of the line going on in the system. So, I cannot figure this out. It just started happening today. It has got to be a hack.
I think I may have overlooked something. This answer may anwer my own question,
"If you select Restart Fascia on the Contextual Ribbon any segments you place after that will be a separate element."
Even after this, though, when I go back to select the Fascia I do not get the Add/Remove Segments button in the Modify Fascias Contextual Ribbon.
