I have to model these stairs in Revit. How do I go about creating the oversize stringers/step? Thanks.
Create a stair type with monolithic option off (construction group on your stair dialog); set tread thickness to the height of the big blocks on your photo (it should be smaller than maximum riser height); set nosing length (tread group on stair dialog) to something like 3cm; set riser thickness to 0; set right and left stringers to none; set middle stringers count to 1 and ajust stringer thickness to be a little smaller than your stair width.
After that you have to set the materials and tweak some more parameters to fine tuning but the basic stair is done.
Gustavo
Hi all, that stair is easy to do. Make a monolithic stair with a tread and nousing of 2" width at the front and both laterals and apply the concrete material. See the attached image.
I hope this will be helpfull. Thanks, alex
