I've had a request from on of our users to replicate something that has been done for years in 2D CAD. They want a marker to show changes in floor levels that look something like this:-
The annotation needs to be able to read the slab on either side of the step marker and hopefully if possible the difference be represented as text. The datum levels are secondary and it is really the depth of the step that seems to be more important. I do however want to avoid these being just dumb text as if/when the design evolves someone will forget to modify the text.
Here is an example of a few showing two steps in the slab and the resilts we would want.
I have tried loading/nesting a standard spot level in thinking if I had two in an annotation that this might work, but I was unable to even place a spot marker within the family which makes some sense I suppose.
Is this even technically possible...??? I realise the origin usually determines what hosts the family and how, but I guess we are looking for something with a double origin, which is why I think this may not be possible...???
Any ideas...?
Thanks in advance and have a good weekend.
At the moment, it is posible to show both the top and bottom spot elevations, but not the the thickness. Probably you can show the thickness in a separate floor tag.
Showing the two elevations, top and bottom, is easy. Just look at the instance properties of the spot elevation, and choose that option for Display Elevations.
Showing the subtraction between the two values is not easy because those two values are not available as parameters. As I said before, you could show the thickness of the slab in a separate tag. However, I think that it is kind of redundant information if the top and bottom elevation are already provided.
Hi, This is a really interesting topic for me...I am doing slabs plans for Archi office and show SFL's throughout as well as level differences.. Issue is the revit family I use is completely manually operated... I just type the difference in Rl's...Its a poor way of doing it because it allows for user errors and doesn't update if the levels change. Is there a family that updates when a level is change / calculates the difference inn levels?? This would be a brilliant family....
