Conceptual mass: create form, how to convert solid to surface?
3 REPLIES 3
samu3
3076 Views, 3 Replies
Hi All,
While working in the conceptual mass environment, I have inserted a closed profile (1 polyline) from a dwg file.
What I need is to either extrude or sweep this profile as a surface, but obviously Create Form only gives me the solid option.
How do I go about doing this?
Thank you,
Samu
3 REPLIES 3
Alfredo_Medina
in reply to: samu3
Redraw that shape using reference lines and splines. When you use Create form on reference lines, Revit gives you two alternatives: surface or solid. When you use model lines, there is no choice, but just solid.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
constantin.stroescu
in reply to: samu3
maybe I didn't understood you well ....
Is this what you want ?:
A
or this ( at what Alfredo refers to 😞
B
If it is A then do the first steps indicated by Alfredo and when you have to select the line segments do it without one segment ( so to have an open shape) and Create Form > Solid Form:
Then , as a last step select the conector segment and Create Form > Solid Form.
Strecth the uper edge till it reach the uther uper edges...
Constantin Stroescu
BIM Manager AGD
samu3
in reply to: constantin.stroescu
Thank you Alfredo and Constantin 🙂
I was referring to A, and you gave me a clear answer.
Thanks again!
Samu
Rail Community
