Revit Architecture
Member
Message 1 of 1 (241 Views)
Composite Walls vs Built-up walls
241 Views, 0 Replies
08-22-2012 02:02 AM
I am after advice on how best to build-up complext external walls that will comprise multiple trades and allow the specialist cladding elements to be replaced by the subcontractor modelled elements: eg I have:
  1. Internal plasterboard lining
  2. metal structural framing with insulation between - specialist design and install
  3. sheathing board - specialist design and install
  4. cladding system - specialist design and install
I can do this to a degree with a Composite walls, but each element will stop and start in different places and each will be installed by a different trade.
is it better to model separately to get better output from QTO and to allow for the replacement of specialist models?
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
