Components Beyond Showing Through Non-Transparent Walls & Roof
2 REPLIES 2
kooldabiz
1670 Views, 2 Replies
Please reference the snip below.  How do I prevent the components beyond the non-transparent walls and roof from showing through. I have double and triple checked the the transparency setting for the walls and roof in 'Override Graphics in View' and they are both set at '0'.  Note these specifics:
  1. Walls: Only the window glass shows through.
  2. Concrete Roof: Everything shows through as if transparency is set at 50%.
KOOLDABIZ
2 REPLIES 2
subsales
in reply to: kooldabiz
It looks like you are seeing the issue described in the following Revit Clinic post:
Glazing Appears Through Walls in Revit 2013
kooldabiz
in reply to: subsales
Halalujah, updating my NVIDIA display card fixed the problem.
FYI, I first checked for updates using Windows Device Manager and it said my Quadro 2000 display card driver software was up to date.  To be sure though, I did a seach via NVIDIA's website at this page http://www.nvidia.com/Download/Scan.aspx
and it recommended an update.  It took 15 minutes of downloading and installing, but wow what a difference.
Thanks for pointing me in the right direction!
KOOLDABIZ
