I'm not sure how to explain this but I'll try. So I've got this existing house with a two stall garage on the lower level. They are adding on two more stalls along with a portion accross the back of the garages. The wall on the back of the garage is at an angle to the rest of the walls. I'm trying to show the home owner that when you build a wall at an angle one of the two roof lines (either at the high wall or at the eave) can not be strait. Only problem is I can not get this to show in Revit? I'm having difficulty Joing roofs and showing the relation. I'm going to attach the drawing file and a few pdf's...
Constantin Stroescu
2 is looking close but the 4/12 pitch roof and the 2/12 pitch roof would need to intersect and create a valley. I've included some screen shots to help with what I'm trying to do. I don't use revit on a regular basis so maybe this is really easy I just don't know how yet! Thanks for the help.
