When you put on an architectural column wall
Join Together they are.
I know that if ,Automaticlly joins when geometry Uncheck the I Join other time will not be.
But my problem. How do I adjust the Once the file is exported to AutoCAD About of architectural columns The line is closed.(But the files be Revit Join Together)
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
