Revit Architecture
Active Contributor
chris.pitt
Message 1 of 2 (174 Views)
Column Display at Different Display Levels
174 Views, 1 Replies
11-01-2012 07:50 AM
Hi
Does anyone have a quick explanation of how to make columns display as columns in the coarse level of detail instead of just as sticks?
I know I'll have to edit the family but I can see anything obvious to change.
Regards
Christopher Alan Pitt
Frank Shaw Associates
Alfredo_Medina
Message 2 of 2 (166 Views)
Re: Column Display at Different Display Levels
11-01-2012 08:14 AM in reply to: chris.pitt
Open the column family, select the extrusion > visibility settings, > activate coarse. Now, do the opposite with the symbolic lines, making them Not visible in coarse level of detail.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
