Hi, I'm using Revit 2013. I have a set of plans with a colour scheme applied to them and I want to make a duplicate set of plans without the colour.
So I've duplicated the views with detailing and made a new view template. Within this view template, I have set the colour scheme to none. However, when I go through and apply this view template to all of my new views, the colour scheme does not disappear. If I look at the view properties, the colour scheme (albeit greyed out) is listed as none but it is still visible in the view. If I remove the view template all together, turn on the colour scheme, then turn it off again, it disappears. I can then reattach the view template and it works fine.
Has anybody else ever experienced this? it's very frustrating and with over 20 views to create it is making a quick simple task take twice as long as it should.
