Patterns in my color scheme now extend into the middle of all walls. Is there a switch to stop the patterns at wall faces?
Try switching the color scheme location between background / foreground from view properties and see if it helps.
That sounded like a really good idea. But no, it doesn't work. Thank you anyway. i'm still trying to find a solution.
How did you create the patterns? Are they surface patterns built into the material for the floor object? Are they filled regions on top of the view?
If it's a surface pattern on the floor, then make sure your walls aren't set to transparent, either in the V/G or by-element. Also check your view templates, if you have any, to make sure that the V/G override there doesn't make the walls transparent.
If it's just a filled region, as I suspect, then you'll have to edit the region boundary to make sure it stays within the walls.
Thanks for your reply. The patterns were created through the Color Fill Legend. When you click on the Color Scheme Legend and choose Edit Scheme your are able to nominate various patterns relating to the floor finishes.
The walls aren't transparent and I've checked the VG over ride etc.
I've passed the problem onto my software supplier who is taking it up with AutoDesk. It may well be a Revit 2012 issue.
I'll post up the answer hopefully, after hearing AutoDesk's response.
Thanks again for your suggestions.
This is definitely an issue with Revit 2012. I have the same issue with patterns even though the same file looks fine in Revit 2011.
Someone asked me this question today so I thought I would investigate. Keep in mind that our color scheme is applied to rooms. If you have the view display set to course, the hatch runs to the center of the wall and ignores the wall fill. If you set the view to medium or fine and set the material fill of the walls to be solid white, then the hatch boundary "stops" at the wall faces. It may not be a complete solution, but it solved our problem. In our case, all of the walls in our project were using the "default wall" for material, so we globally edited the material through Manage tab>Object Styles>Model Objects>Walls> change the default wall material to a material with Graphic properties- Cut Pattern >Solid fill, white. You may also apply this material per view instead of globally through visibility graphics.
Josh Siddle
The Freelon Group
hello i solved the problem is not an issue . you just have to go to view- visibility/graphics under room category -uncheck (color fill) and check (interior fill)
how can i use model pattern in color scheme's fill pattern ?
fill pattern in color scheme only shows drafting pattern ...
