I am having a problem with my color fill for room areas. The color is covering some components but not others; for instance, I can see my toilets but my toilet partitions and doors are covered. How do I fix this problem? Any help is greatly appreciated! Thanks!
try these:
My visual style is set to hidden lines and color scheme is already set to background. Any more thoughts?
did you verified Phasing ?....maybe that walls are in a different phase...
Hi there, my phases for components showing and covered are set to New Construction and None. Is there a way to change a phase for color fill?
I 'll make another try.....
Could it be a Filter applied in Visibility/Graphic Overrides for that type of wall ?
For instance - A filter in which Visibility is unchecked....
Does it happens only in this file?.....not to be a bug....
Hi all,
I appreciate the suggestions but unfortunately none of those options worked. Are there anymore thoughts?
Thank you to everyone so far!
