Changing door and window frames
1 REPLY 1
1402 Views, 1 Reply
How do I change the default door and window frames to match? Ideally, change the default window frame to appear like the default door frame?
1 REPLY 1
Match it to what...shape, size, lineweight, color...? You can probably
answer your own question by going into the family and looking at how it was
built. Click on the family in question and select Edit Family. You can
also go to Settings -> Object Styles and search for Door or Window and check
on those settings. Provide some more info and we can better answer your
question.
wrote in message news:5371705@discussion.autodesk.com...
