Change a walls default top constraint?
4 REPLIES 4
AlexDT
1339 Views, 4 Replies
How can I change the default top constraint for all my walls!
Some are by default constraint to the first floor, others are unconnected! That makes me think I can change it! ... But how??
4 REPLIES 4
cvandevere
in reply to: AlexDT
I beleive when you place a wall and make constraint changes in the property panel it rembers that change the next time you place a wall. The changes must be made prior to placing the wall. Hope this helps.
CDV
AlexDT
in reply to: cvandevere
Yeah I thought so too. It was the first thing that I tried. Does it work for you? It does work for me unfortunatly!
AlexDT
in reply to: AlexDT
Can anyone shed some new lights on this problem? Bug?
p00410441
in reply to: AlexDT
It's same to me! My Default Top Constraint is always -1931 and I want to set it O. Someone can help plz?
