Is there a simple way of raising one end of a wall to get a sloped top? Please see attached.
Solved by constantin.stroescu. Go to Solution.
Solved by SteveKStafford. Go to Solution.
select the wall you want to change > Mode > Edit Profile - once entered in Sketch Mode draw the wanted profile > Finish Edit Mode...
Constantin Stroescu
