Central vs Local
1 REPLY 1
mika.niklander
362 Views, 1 Reply
Central vs Local
Should I open Central file from our server and create new local, or should I open my local file and reload latest (or synchronize)? Does it really matter which way to do it, or is there a technical reason to do it either way? Or, is it better to open central just in case to be certain that I'm using the latest file?
MiNi
1 REPLY 1
in reply to: mika.niklander
Best practice for teams using a Central/Local file system is for each user to Open Central and Create New Local
each day, or when restarting Revit after a long absence during the day.
Opening Local and STC is a bad habit and if many users adopt this, there is a risk that local files will become incompatible with Central, and potential work could be lost or it may be difficult to get a local user's work copy/pasted
into the Central from an incompatible local.
cheers
