Revit Architecture
revitman91
Message 1 of 4 (166 Views)
Accepted Solution
Ceiling Question
166 Views, 3 Replies
06-13-2013 04:43 PM
Hi, I am trying to figure out why I have no ceiling when I change the height from 8'-0" to 9'-0". Soon as I change it, my ceiling disappeares where all I can see is the roof from the inside. Also, the ceiling in two rooms seemed to have stayed in place at the 9'-0" height, but I can't place any lighting fixure in the ceiling unless I make it 8'-0" again... Any help will be much appreciated. Still learning this softwear.
*Expert Elite*
rosskirby
Message 2 of 4 (165 Views)
Re: Ceiling Question
06-13-2013 04:52 PM in reply to: revitman91
Go to the properties of your RCP, and make sure that the view range is set so that the view extents go beyond the highest ceiling, otherwise it won't be visible in the view.  Rather than trying to figure out exactly what height to set it at, just change it to unlimited, and click Apply.  You should see the ceiling then.
Ross Kirby
BIM Manager
Arcturis
revitman91
Message 3 of 4 (157 Views)
06-13-2013 05:13 PM in reply to: rosskirby
That did the job! Thank you.
*Expert Elite*
rosskirby
Message 4 of 4 (142 Views)
06-13-2013 07:02 PM in reply to: revitman91
You're welcome.  Glad I could help.  View ranges can be tricky.
Ross Kirby
BIM Manager
Arcturis
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
