Ceiling Grids on Reflected Ceiling Plan
1 REPLY 1
1233 Views, 1 Reply
I need to change a setting somewhere when I'm placing a 2x2 ACT grid on the Reflected Ceiling Plan.
When I put in the parameters that it's 8'-6 aff it doesn't show on the RCP but shows up on the section. When I lower it to 7'-6" on the section, it shows up on the RCP. How can I make it show up on the RCP at 8'-6" aff ?
Can someone walk me through the process? I have something set that's not letting me see the grid at a certain height on the RCP.
Thank you!
1 REPLY 1
Go to the view properties of the RCP and check the view range. Your ceiling
should fall within the view range to be visible.
Nicholas Iyadurai
http://revitize.blogspot.com/
"susancheek6695" wrote in message news:6226231@discussion.autodesk.com...
Thank you!
