Revit Architecture
*Doug
Message 1 of 4 (39 Views)
Catalog Problem
39 Views, 3 Replies
07-28-2004 10:45 AM
I have entered all of the info for a window catalog into excel and saved it to a coma delimited file, how do I change that into a txt file? Thanks Doug
*Aaron Rumple
Message 2 of 4 (39 Views)
Re: Catalog Problem
07-28-2004 10:45 AM in reply to: *Doug
Change the file extension to *.txt(?) "Doug" wrote in message news:4107e62a_2@newsprd01... > I have entered all of the info for a window catalog into excel and saved it > to a coma delimited file, how do I change that into a txt file? > > Thanks > > Doug > >
*Doug
Message 3 of 4 (39 Views)
Re: Catalog Problem
07-28-2004 10:51 AM in reply to: *Doug
nope tried that... sill in columns thanks Doug "Aaron Rumple" wrote in message news:4107e6e2$1_3@newsprd01... > Change the file extension to *.txt(?) > > "Doug" wrote in message > news:4107e62a_2@newsprd01... > > I have entered all of the info for a window catalog into excel and saved > it > > to a coma delimited file, how do I change that into a txt file? > > > > Thanks > > > > Doug > > > > > >
*Scott Davis
Message 4 of 4 (39 Views)
Re: Catalog Problem
07-28-2004 11:10 AM in reply to: *Doug
When you create the CSV file, and rename it to TXT, is it still opening in Excel when you double-click it? It should open in Notepad or some other text program. If the TXT file is opening in Excel, right-click the file name, and go to Open With and select Notepad. This should open now as a comma delimited text file. Save it from Notepad, and all should be well. "Doug" wrote in message news:4107e7a5$1_3@newsprd01... > nope tried that... sill in columns > > thanks > > Doug > "Aaron Rumple" wrote in message > news:4107e6e2$1_3@newsprd01... > > Change the file extension to *.txt(?) > > > > "Doug" wrote in message > > news:4107e62a_2@newsprd01... > > > I have entered all of the info for a window catalog into excel and saved > > it > > > to a coma delimited file, how do I change that into a txt file? > > > > > > Thanks > > > > > > Doug > > > > > > > > > > > >
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
