Using revit 2014. Although the duct is higher than the walls, the walls are overriding the duct. I want the duct to override the walls. Cant seem to make this work and dont understand why. Any suggestions would be greatky appreciated. Please see attachement to understnad what I am looking at. Many thanks.
Solved by thoov106. Go to Solution.
My guess is your view cut plane is set below your duct height. In order for the duct to override the wall you need to place a plan region over that portion of the wall and set the height of your plan region to the height of the duct.
TH
