Cant find the navisworks exporter in revit 2014
2 REPLIES 2
jsteadman
6491 Views, 2 Replies
I have installed the Navisworks Exporter Plug-in tool but, I can't find it any where in Revit. i have Navisworks manage 2014 installed as well as Revit 2014. where does it go once you have installed it?
In Revit 2013 its under add-ins - External tools, but Revit 2014 dose not have External tools they are separate
Any ideas?
2 REPLIES 2
Jason_S
in reply to: jsteadman
The same thing happened to me.  I tried to do a reinstall or repair and that didn't work.
So I went to here and downloaded it separately and installed now I have it.
http://www.autodesk.com/products/autodesk-navisworks-family/autodesk-navisworks-nwc-export-utility
Lance.Coffey
in reply to: Jason_S
If the regular NWC export utility installer doesn't work, you can also try the updated exporter version (Autodesk_Navisworks_Exporters_2014_ML_Win_32_64bit_R1_dlm.sfx.exe) released with Navisworks Service Pack 1.
Lance Coffey
Technical Support Specialist
