Im trying to pick a different component, but always the same one comes up. It seems like the only ones that work are the ones inside the drop down menu. I cant pick any new components from other folders? They were working before, but not anymore.
Seems very strange.... Can anyone help?
Unfortunately I am not sure I am clear on the issue. Do you think you could provide a little more detail as to what the problem is - maybe with a set of steps we can follow or a screenshot?
What did you do to fix this problem? I've run into the same issue and can't seem to find much about it. Thanks.
If you are experiencing the same issue, would you be able to provide a little more detail as to what the behavior is that you are seeing?
