I briefly search for this topic and found nothing, forgive me if it has already been discussed.
Why am I not able to select Line Styles in the family editor? This is the case for both creating new families and editing existing ones. See attached image for clarification
This is by design (not a bug). The line styles are defined in a project(template) not in the family.
I think it is done so that similar objects/categories will get a similar look in the project and therefore more consistent look and feel. It also prevent that you will get many linestyles in your project when importing lots of families into the project.
Louis
Please mention Revit version, especially when uploading Revit files.
What you say makes sense. But oddly enough its the inconsistancies that have have me wanting to make line style changes. So, if I define the line styles in my template how does that translate to the object? For instance, I insert a 2x10 detail component and it's perimeter line is just way too heavy. How do I change that?
It depends a little bit on your workflow. I tend to work with object styles
In my family, I assign different objects to different object styles. If needed I create additional object styles.
If I insert that family into the project those object styles are carried over to the project.
I can now override the different object styles in my views by making modifications in"Visibility/Graphics Override".
It is even possible to make (some) modifications for each element, by selecting the object, right click, "override graphic in view", "by element".
Louis
Louis
Louis
Add new line styles in a detail family by:
Manage > Object Styles > Modify Subcategories > New !
