Cannot see Link autocad files revit 2012
1 REPLY 1
ennujozlagam
1117 Views, 1 Reply
hi Guys,
Maybe you could help me with this problem. i tried to link autocad files im my revit but i cannot see the files anywhere even in manage link
when clik yes (please see attached) still the same. What could be the problem.Please help
Thank you in advance.
1 REPLY 1
CoreyDaun
in reply to: ennujozlagam
Make sure that you are Linking the DWG file, and not just Importing it. Linking is akin to Xref-ing in AutoCAD and the file should appear in the Manage Links dialog, under the 'DWG Formats' tab. Importing is the equivalent of inserting a block in AutoCAD - the imported DWG object will retain no connection to the original file.
When you import or link a DWG file into a View, Revit will want to import the contents of that file's Model Space. If imported/linked into a Sheet, then Revit will want to import the contents of Paper Space. From the image you posted, you are attempting to Import/Link a DWG file into a View, but the DWG file does not contain any information in Model Space. If this is not the case, can you post the DWG file here?
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
