Revit Architecture
Product Support
rene.sommer
Message 1 of 2 (412 Views)
Cannot purge unused dimension styles
412 Views, 1 Replies
07-14-2011 07:34 AM
I had a user ask why some dimension styles cannot be purged even if all the dimensions are deleted from the project.
Most probably the dimension style is used in a family that is loaded in the project.
When you select all dimension instances in the entire project, it will not select those included in the families. But the purge function will 'see' that it is still used in a family and therefore it will not be listed in the purge dialog.
So you will have to find in which family the dimension style is used.
I don't think there is an easy way to do it. I would make a copy of the project and then delete a bunch of families until the dimension style can be purged, then refine the research until to find the family that contains the dimension style.
Rene Sommer
New Member
Message 2 of 2 (227 Views)
Re: Cannot purge unused dimension styles
01-14-2013 11:11 AM in reply to: rene.sommer
Revit doesn't select dimensions in the "Legends". So you won't be able to purge any dimension styles within the Legends.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
