Revit Architecture
Valued Contributor
Message 1 of 5 (226 Views)
Cannot get rid of beyond lines
226 Views, 4 Replies
04-16-2012 09:09 AM
Beyond lines displaying for walls of floor below and cannot get rid of - view range is set with bottom offset at floor level, cannot override beyond line style and nothing else I can find to turn them off. Its walls, door openings (not symbolic lines etc.
Alfredo_Medina
Message 2 of 5 (225 Views)
Re: Cannot get rid of beyond lines
04-16-2012 09:10 AM in reply to: timandjo
Check the Underlay property of the floor plan view. Is it set to show the floor below?
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
Valued Contributor
Message 3 of 5 (198 Views)
04-17-2012 06:44 AM in reply to: Alfredo_Medina
Thanks - yes thats what it was.
Alfredo_Medina
Message 4 of 5 (194 Views)
04-17-2012 06:48 AM in reply to: timandjo
Good. Then please mark the Solution.
Active Contributor
Message 5 of 5 (97 Views)
01-08-2014 11:42 PM in reply to: Alfredo_Medina
I can't make him mark it as the solution, but I'll give you some kudos instead. :-)
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
