Cannot get rid of beyond lines
4 REPLIES 4
timandjo
853 Views, 4 Replies
Beyond lines displaying for walls of floor below and cannot get rid of - view range is set with bottom offset at floor level, cannot override beyond line style and nothing else I can find to turn them off. Its walls, door openings (not symbolic lines etc.
4 REPLIES 4
Alfredo_Medina
in reply to: timandjo
Check the Underlay property of the floor plan view. Is it set to show the floor below?
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
timandjo
in reply to: Alfredo_Medina
Thanks - yes thats what it was.
Alfredo_Medina
Good. Then please mark the Solution.
I can't make him mark it as the solution, but I'll give you some kudos instead. 🙂
