Cannot get crown or base moulding to miter
7 REPLIES 7
Message 1 of 8
1950 Views, 7 Replies
Hi! I am using Revit 2013 & am doing some basic "Sweeps" with the base & crown moulding. The problem I'm having is that they run the full length of the wall instead of stopping at interior walls. They will not miter at intersections at all. Someone on Youtube showed how to do this by "splitting" all of the walls in order to get the moulds to terminate and properly miter. Even that doesn't work sometimes unless the split liine is exact to the wall. Any other ideas on how to do such a simple sweep.!
Paul
7 REPLIES 7
Message 2 of 8
Alfredo_Medina
An easy way to get the crown moulding to miter the corners is to create a wall type that includes the profile of the crown as a sweep.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
Message 3 of 8
in reply to: Alfredo_Medina
Thanks Alfredo! That does make sense. Only problem is not all walls will
have moulds. I guess I would have to make specific wall types to show the
interior Crown & base mould sweeps. It would be so much easier if you could
just apply the moulds & miter them. Maybe for the "Wish List"!
Paul
RYMAL DRAFTING INC.
EDMONTON, ALBERTA
(780)634-5303
Message 4 of 8
constantin.stroescu
No matter how is made the sweep profile on wall can be stretched.
As can be seen in the example from below made in Revit 2012...
  • The wall from right is a type of wall with sweep made in Edit Assembly (as Alfredo suggested)
  • The left one is a simple basic wall on wich was applied: Wall>Wall Sweep ..
  • The mould Profil has to be at the same level the same profile  and of the same material.
  • Select the sweeped Mould and drag the Point (Drag Wall Sweep End ) as shown in the example..
  • The sweep stretches and conects automaticaly with the other one
Constantin Stroescu
Message 5 of 8
in reply to: constantin.stroescu
HI Constantin! Thanks for the reply. I am aware of being able to drag the sweep ends, but no matterhow close I drag them to each other they will not 'Miter"!
Paul
Message 6 of 8
constantin.stroescu
the walls must be joined...
be sure you are on "allow join"..RC on the Drag Wall End point to activate allow join if it isn't....
Image 254 -when allow join is active
Image 256 - whe disalow join is active....RC and check allow join
The image are from a 3d view -Top....
Check also if not your Snaps are not off...Manage>Settings >Snaps Off must be unchecked ...the snaps must be active...
Constantin Stroescu
Message 7 of 8
I agree with Constantin. This usually works with no problems. Double check the settings that have been suggested: same elevation, same profile, etc.
Message 8 of 8
Thanks everyone for the help on this one. It was a bit tricky. I found that I was not carefully dragging my ends to line up properly as well as splitting the walls which did not help.
Paul
