Revit Architecture
Mobius00
Message 1 of 8 (1,282 Views)
Cannot create Wall By Face
1282 Views, 7 Replies
07-22-2010 09:00 PM
I create a Conceptual Mass like a turtle shell. But I cannot crate Roof or Wall by Face from Massing.
Have you got any solution?
thank,
Mobius00
Alfredo_Medina
Message 2 of 8 (1,261 Views)
Re: Cannot create Wall By Face
07-24-2010 05:25 PM in reply to: Mobius00
Can you post an illustration? A picture is worth a thousand words...
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
Mobius00
Message 3 of 8 (1,242 Views)
07-26-2010 07:05 PM in reply to: Alfredo_Medina
this is an image.
thank you,
Mobius00
lawrencerobinson5
Message 4 of 8 (1,214 Views)
07-27-2010 08:19 AM in reply to: Mobius00
If your mass has no depth, meaning it is just a mesh, then you cannot model by face.  It does appear that it has not depth from the image so this is likely the issue.
Lawrence
lawrencerobinson5
Message 5 of 8 (1,195 Views)
07-27-2010 10:50 AM in reply to: Mobius00
I created a family that has thickness rather than being a mesh, that you can manipulate to be very similar to what you created.  This family does allow you to model by face.  Take a look at it and see what you think, at very least it should give you an idea about how to make your form work.  Look at all the parameters and you can see a little more clearly how to manipulate it.
If you have any questions about it just ask.
Lawrence
Mobius00
Message 6 of 8 (1,175 Views)
07-27-2010 07:59 PM in reply to: lawrencerobinson5
thank you, Lawrence
Now I can create "wall by face" to my conceptual model.
but when I try to create "roof by face" from same model. it still cannot.
have you got any idea?
Mobius00
lawrencerobinson5
Message 7 of 8 (1,171 Views)
07-27-2010 08:10 PM in reply to: Mobius00
Revit can be a bit of a pain when it comes to creating a roof by face.  In the case of the family I posted you can set the parameters such that the program will not make a roof  and then if you change a dimension or 2 it will make the roof.  There apparently are some limitations to the geometry that revit will let a roof be formed in.  Unfortunatley there does not seem to be any documentation that specifically descibes the limatations of roof creation.  Hopefully autodesk will read this and provide some documentation.
Lawrence
Active Contributor
cwinches
Message 8 of 8 (103 Views)
01-27-2014 04:20 PM in reply to: Mobius00
Actually, I'm fairly certain you can create a wall by mesh (mass face with no depth). Roofs as well. Perhaps this had been addressed in the releases since the last comments.
Cheers.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
