Revit Architecture
Valued Contributor
timandjo
Message 1 of 3 (109 Views)
Cannot add any new objects
109 Views, 2 Replies
05-31-2012 07:54 AM
Am getting warning "None of the created elements are visible in Floor Plan: 00 GF View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings". Phase settings are correct, no hidden elements etc etc. Cannot add anything by create similar, build panel. Its Revit 2013 - I have been getting alot of cannot continue crashes but is this a forthcoming fix issue?
Valued Contributor
timandjo
Message 2 of 3 (106 Views)
Re: Cannot add any new objects
05-31-2012 07:58 AM in reply to: timandjo
AND I can add window and door objects by create similar but it produces an empty opening with no other bits of the familiy
Valued Contributor
timandjo
Message 3 of 3 (84 Views)
06-01-2012 04:14 AM in reply to: timandjo
SORTED - I turned off worksharing by detatch from central and discard worksets. All the failed new objects littered all over the place so were placed but not visible. Absolutely no idea why!
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
