Cannot Open .rfa File
16 REPLIES 16
Message 1 of 17
shadowx360
9905 Views, 16 Replies
Hello, I have a .rfa file, but I don't have Revit on the setup I'm using right now, is there any way to convert the .rfa file into a 3D DWG file that I can open in AutoCAD 2011?
The file is attached, and I would be forever grateful if someone can find a way to let me get a 3D DWG out of it.
16 REPLIES 16
Message 2 of 17
OZRevit
in reply to: shadowx360
Hi, Would DWG 2010 help you? Sorry don't have 2011
HTH
Message 3 of 17
shadowx360
Thank you so much!!! That is much appreaciated!
Message 4 of 17
OZRevit
Glad I was able to help!
Message 5 of 17
gymjumpertje
in reply to: OZRevit
I have the same problem. Can you please convert my file too?
Thanks!!
Message 6 of 17
OZRevit
The 3D DWG file is attached.
HTH
Message 7 of 17
adpi-me
Please help with this file as well.
Thank you
Message 8 of 17
bone14701
OZRevit What Autodesk program are you using to convert?
Message 9 of 17
cadguydrafting
could you convert this file for me.
thank you,
Message 10 of 17
bone14701
in reply to: adpi-me
Message 11 of 17
bone14701
in reply to: cadguydrafting
Message 12 of 17
jamiefindler
Hi there guys, i am new to this forum and I am suffering with this same problem. Please could somebody kindly convert the attached RFA file to Autodesk Inventor Professional 2012 friendly? Thanks very much
Message 13 of 17
adrian.gatdula
in reply to: bone14701
Hi, i also needed anyones help in converting the .rfa to .dwg. can anyone help me please...here is the file...
Message 14 of 17
lmunozaq95
Tags (2)
Message 15 of 17
ultigroup01
Would someone please be able to convert this file into a .pdf or something similar, as i do not have the correct program to view it in??
Please help!
Trent
Message 16 of 17
aconrad
Can someone convert this file for me as well
Message 17 of 17
hsonier
in reply to: aconrad
Can someone help me out as well?
Thanks in advance!!!!
