Hello, I have a .rfa file, but I don't have Revit on the setup I'm using right now, is there any way to convert the .rfa file into a 3D DWG file that I can open in AutoCAD 2011?
The file is attached, and I would be forever grateful if someone can find a way to let me get a 3D DWG out of it.
I have the same problem. Can you please convert my file too?
Thanks!!
Please help with this file as well.
Thank you
could you convert this file for me.
thank you,
Hi there guys, i am new to this forum and I am suffering with this same problem. Please could somebody kindly convert the attached RFA file to Autodesk Inventor Professional 2012 friendly? Thanks very much
Hi, i also needed anyones help in converting the .rfa to .dwg. can anyone help me please...here is the file...
Would someone please be able to convert this file into a .pdf or something similar, as i do not have the correct program to view it in??
Please help!
Trent
