I'm currently working on Revit 2011 and whenever I try to put in the sidelites into the project, I get this message:
Cannot Load Family Files
Some or all of the family files you selected cannot be loaded. You must choose the family files of the category Component.
I've tried putting the sidelite by going through Door first. I've tried going through Component. It gives me pretty much the same message.
Solved by loboarch. Go to Solution.
I'm having the same problem tryin to load detail components. I'm trying to load Metal Stud details under the component option and I'm recieveing the same error message.
You will need to load those as "detail components" you can't be using the "component" tool and then try to load and place a "detail component" Start from the Anotate tab and then select "Detail Component" from the drop down. Now you can load the metal stud details.
After drawing a column, I tried to put footing to the column. Then while loading the footing from family (Metrics > Structure > Foundation > Footing-Rectangular.rfa) I get the below error message,
some or all of the family files you selected cannot be loaded. You must choose the family files of Category Structural Columns. Do you want to try loading a new set of files.
Please anyone help me to sort the above issue out.
Pallavi
Jeff:
I logged a request to fix this behavior with Adesk. It would be SO nice if the reviet would say:
This is a a detail component family, not a window family. Would you like to add/load the detail component instead?
Not a part of the 2012. Seemed simple enough.
bt
Can anyone help me. I hv tried to load family for structural columns but have failed miserably. Would appreciate idf anyone is able to assisst step by step. thank you.
I ran into a similar issue and after my own troubleshooting figured out that my error was resulting from attempting to load a "Structural Framing" category family to use as a column... because, logically, a steel column IS structural framing. However, Revit has its own category for columns, which when you find it has the same HSS, etc. shapes as in the Steel Framing category.
Hope this helps someone out.
I am also facing the same problem in revit architecture 2012 while loading imperial rectangular column family.
displays the same message as above. please guide.
I'm using revit 2016, and having troubles to load families. I'm getting the message "Some or all of the family files you selected cannot be loaded. You must choose family files of the category Component. Do you want to retry loading a new set of files?". However, I'm doing the path Insert > Load from Library > Load Family. The family shows up in my project browser, but beit doesn't appear when I look for components. How could I solve this? Thanks!
Hi Everyone,
I tried to load a single arrow from detail components.
It gives me the same error message,
What Should I do?
Thank you !
