Revit Architecture
marcus
Message 1 of 3 (226 Views)
Can you edit floor sub-components in section?
226 Views, 2 Replies
11-14-2012 08:53 AM
I have a floor joist/subfloor/finish floor system where the joists are hung from the sill inside the foundation wall, this means that the joists stop at the wall but the subfloor will continue over the sill plate and the finish floor will stop at the inside edge of the bottom wall plate.  As near as I can figure, in order to get this to show correctly in section I really need to create the complete floor assembly by stacking 3 separate floor sub-assemblies (framing, sub-floor, finish floor) is this correct? (this is the method I'm currently using) Is there a way to manipulate the sub-components in section that I haven't found?
LisaDrago
Message 2 of 3 (201 Views)
Re: Can you edit floor sub-components in section?
11-19-2012 06:19 AM in reply to: marcus
Hello Marcus - what you currently have is correct.
If you need to manipulate the materials separately you would need to place them separately and layer them on top of each other.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
marcus
Message 3 of 3 (178 Views)
11-20-2012 06:06 AM in reply to: LisaDrago
Lisa,
Thanks for your feedback, that's kind of what I figured.
I haven't had to try it, but I'm going to assume that roofs behave the same way.
Maybe this could be a wish list item...if there was a Revit Architecture wish list.  I guess that getting an RA wish list would be a wish list item as well?? lol
Marcus
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
