Can't select walls attached to the roof.
1 REPLY 1
jdsignom
254 Views, 1 Reply
Hi, I can't select walls (directly or through the filter) if they are connected to teh roof.  I can select and edit components in the walls but that is all.  If I delete the roof the attached walls (interior and exterior) also delete.
1 REPLY 1
Can you send me your project file?
