Hello all,
I am having a very strange issue that appears in the Materials editor within Revit 2013 Update Release 3. If I change a surface or cut hatch pattern within the editor, and then attempt to close out of the editor, go to a different material, or apply the change, the hatch dialog pops right back up again, as if I never closed it. I have found two ways to get out of this obnoxious loop:
1. Use the 'esc' key to back out of the materials dialog (unfortunately no changes are saved).
2. Change the color of the hatch - this allows for the changes to be applied etc.
I've tried resetting the UI and reinstalling Revit to no avail. Is anybody else having this issue?
i also have this issue; the workaround described above works for me, but I have not found another solution to this.
