I was rendering my revit drawing using 2 pcs and know i am wondering how i would import these rendered images into the 1 drawing?
Solved by sagar.londonites. Go to Solution.
I am not really sure what you are asking but I will take a stab. You save a rendered image from revit as a jpg then import that jpg image back into another revit file. Hope that helps.
Sorry we're not on the same wave length, i mean as i rendered the image on another pc can i then import both the 3d view and rendered image of that drawing into the 3d view and rendered image tab of another drawing, so basically i would need all 3d views and rendered images in 1 drawing.
Sorry hope this explains what im after.
Yes sorry this is what i meant. I am still in Autocad speak.
This should do the trick.
Thanks.
