Hello I have a family that I made that is based off a 'Metric Generic Model line based' template.
Can a FamilyInstance of this type (Line Based) have z values? Ie, can the start point of the line/FamilyInstance be higher than the end point of the line/FamilyInstance?
If not, what template can I use that will allow me to have a line based FamilyInstance with heights (like in the below image)? I am aware I could use the 'Metric Structural Framing - Beams and Braces' template can achieve what I am asking but Revit always tries to auto-join these FamilyInstances with the next closest FamilyInstance by default. I know I can turn this functionality off but it would be easier to just use a template that doesn't involve this in the first place. Maybe 'Metric Structural Stiffener Line Based'? The reason why I ask is that I am programmatically creating a FamilyInstance and its Z heights are'nt working, ie, I create it with the start and end heights; 30, 50 but they have the start & end heights of zero?
sam.z
Hey 🙂
Yes you can give variable offset values for the start and end point of line based families.
Create your normal parameters (Width, height) then follow these steps:
I’ve attached the family file as well.
Hope this helps
If you need any further explanation just say so 🙂
Using Generic Model Line Based :
In order to control better the xy of the bar slope I propose to use another method:
The parametric family is in attachmet......
Constantin Stroescu
